楼主: Moto17
凯旋 Triumph 使用TigerTool最新版全系列车型免费清除保养提示教程【202405】
升级   73%
  • 签到天数: 9 天
    Trident660
    发表于 2025-10-13 08:26:30 | 显示全部楼层 IP属地: 浙江省杭州市
    lion0350 发表于 2025-10-9 08:49
    台灣這也進不了…
    那确实没办法了,只能等等楼主了
    升级   18.89%
    昨天 10:01
  • 签到天数: 60 天
    发表于 2025-10-14 16:03:40 | 显示全部楼层 IP属地: 北京市
    Moto17 发表于 2025-8-21 12:12
    好的,感谢提醒,如果有的话,本站尽快发布❤️
    版主还没更新3.7嘛
     楼主| 发表于 2025-10-15 11:22:12 | 显示全部楼层 IP属地: 上海市
    Watson 发表于 2025-10-14 16:03
    版主还没更新3.7嘛
    目前暂未找到资源,国外论坛上不去,持续追踪中~
    升级   98.82%
  • 签到天数: 295 天
    发表于 2025-10-16 00:24:40 | 显示全部楼层 IP属地: 台湾省
    我是2022年Tiger 900 車主,3.7版是2025/07/18發佈的,新版能支援2024年式6 pin接頭的tiger 900的保養重置,詳細說明原文說明如下..
    TigerTool V3.7 is now released.  :152:
    NOTE: You MUST be logged-in to the forum to see, and download, the attachments below.  :015:
    TigerTool ONLY works on devices running the Windows operating system!
    Despite the name, TigerTool covers many other Triumph models. This full release now has service interval reset (and other function) support for the Gen2 Tiger 900 family, Gen4 Tiger 1200 family and the Tiger Sport/Trident/Daytona 660 family.
    TigerTool was originally written to reset the service interval on the Tiger 800, but now the following models should have native support. Other models can easily be tested by using simple command-line switches. Support for some models may be limited so not all features will be available. Details on how to try TigerTool with other models are included in the instruction document.
    Note: On a few models there may be some features that do not (yet) work, e.g TPMS access on the Gen2/3 Explorer/1200 models.
    Tiger 800 / XR / XRX / XRT / XC / XCX / XCA
    Tiger 900 / GT / GT Pro / GT Aragon / Rally / Rally Pro / Bond / Aragon - Gen1 & Gen2
    Tiger 850 Sport
    Tiger Explorer / Explorer XC - Gen1
    Tiger Explorer & 1200 / XR / XRX / XRT 200 XCX / XCA - Gen2 & Gen3
    Tiger 1200 Alpine / Desert
    Tiger 1200 GT / GT Pro / GT Explorer / Rally Pro / Rally Explorer - Gen4
    Trophy
    Trophy SE
    Tiger Sport 660
    Trident 660
    Daytona 660
    Tiger Sport 800
    Street Triple R
    Street Triple RS
    Street Triple RS 765
    Street Triple Moto2
    Speed Triple 1200 RS
    Speed Triple 1200 RR / Breitling
    Twins:
    Bonneville T120 / Bobber / Speedmaster
    Scrambler 900 / 1200 X / XE
    Speed Twin 900 / 1200 / RS
    Street Twin 900
    Thruxton RS
    V3.7 includes features to allow the user to do the following:-
    • Reset the service interval and clear the 'service due' wrench symbol from the instruments
    • Read & clear diagnostic trouble codes (DTCs) and the Malfunction Indicator Light (MIL)
    • Configure ABS / TPMS menu items & default distance units for the instruments
    • Erase Immobiliser/TPMS DTCs and monitor live TPMS data
    • Read VIN, ECU serial & engine map reference codes
    • Read, enable/disable & program TPMS sensors
    • Check throttle body balance
    • Bleed ABS brake modulator
    • Read & clear ABS DTCs
    New features and bug fixes since V3.51 was released:-
    • Added service reset support for Gen2 Tiger 900s, Gen4 Tiger 1200s and Tiger Sport/Trident/Daytona 660s
    • Improved support for bikes with no VIN after ECU replaced (see instruction document)
    • Improved instrument detection and data reading, especially for TFT displays
    • Added batch files for testing TigerTool on models not currently supported
    • Updated VIN decode to identify models from different global markets
    • Added VIN decode support for many additional models
    • Added several new DTCs
    DISCLAIMER
    These instructions and the attached software are provided as-is and without warranty of any sort.
    The software is provided free of charge for non-commercial use. It allows the user limited access to the ECU on a wide range of Triumph models and can be used to perform various functions as part of a regular maintenance and/or servicing schedule.
    Using this software, and the consequences therein, remains the sole responsibility of the user. Neither the author nor anyone associated with the officially supported forums will be held liable for any subsequent costs, losses or damages as a result of downloading, installing or using this software.
    The software MUST NOT be copied to other websites, internet forums, social media sites etc without the express written authority of the original author. Software support and new releases will only be provided by the author via the forums at www.tiger800.co.uk, www.tiger-explorer.com, www.tiger660.com, www.trident660.com, www.tiger1050.com and www.triumph-trophy.com
    All reasonable steps have been taken to ensure the accuracy of the instructions and suitability of the software, but be aware that editing or modifying your bike's ECU may cause undesirable effects and/or invalidate your warranty. The software has been scanned at VirusTotal prior to release.
    OBD Interface
    As with all previous versions of TigerTool, accessing ECU data can be achieved using the ISO9141-2 and ISO15765-4 (aka CAN bus) protocols. This software is intended to work with most USB & Bluetooth ELM327-based OBD2 interfaces, including the OBDLink range. See the link below for interfaces that I recommend.
    There are a number of interfaces around that don't work with TigerTool because they contain very poor quality components and/or firmware and don't support some the of the basic ELM327 commands that are needed. Ensure that you have the latest drivers for the device that you're using to support the version of Windows that your PC is running. DO NOT install any drivers that may be supplied with your interface lead or via a download link as Windows 'should' take care of installing the correct driver for you.
    NOTE:
    • This software WILL NOT work with the VAG/KKL leads such as those from Lonelec that are used with TuneECU on Windows.
    • This version supports ELM327 OBD2 interfaces that are V1.n or V2.n.
    See this link for leads that I recommend
    Installation
    TigerTool is a standalone Windows application (on all versions from XP to 11) that needs no installation process and no additional files to run. You can manually add a shortcut to your desktop to make access easier if you like. Although not a requirement, it is recommended that you put TigerTool in its own directory (e.g. C:\TigerTool). Using desktop shortcuts and a dedicated directory will help if you plan to try using TigerTool with other Triumph models.
    A NEW 33-page instruction manual (PDF) has been written and should be consulted before asking questions on the forum! This file contains some important information so you MUST download and read it thoroughly before using the software.
    CAUTION:
    • ALWAYS use TigerTool versions downloaded from this and the other supported forums (as noted above) or from the approved / recommended interface lead provider BMDiag in the link above.
    • DO NOT trust versions that may be bundled by sellers with some interface leads, either as web links or supplied on CDs and USB memory sticks. The validity of these versions or the suitability of the leads cannot be guaranteed.
    升级   39%
    发表于 2025-10-16 17:06:28 | 显示全部楼层 IP属地: 山东省济南市
    6666 CENGYIXIAZHANGJINGYAN1
    升级   73%
  • 签到天数: 9 天
    Trident660
    发表于 2025-10-18 15:32:10 | 显示全部楼层 IP属地: 浙江省湖州市
    sneo 发表于 2025-10-16 00:24
    我是2022年Tiger 900 車主,3.7版是2025/07/18發佈的,新版能支援2024年式6 pin接頭的tiger 900的保養重置 ...
    兄弟,这个帖子里面,没有给什么下载的链接之类的吗
    升级   98.82%
  • 签到天数: 295 天
    发表于 2025-10-19 00:17:39 | 显示全部楼层 IP属地: 台湾省新北市
    有3個下載連結,請您試試看是否能下載..
    * TigerTool V3.7.zip (379.7 kB - downloaded 613 times.)
    https://www.tiger800.co.uk/index ... 4101.0;attach=30583
    * TigerTool V3.7 Instructions.pdf (2411.23 kB - downloaded 501 times.)
    https://www.tiger800.co.uk/index ... 4101.0;attach=30584
    * TigerTool Batch Files.zip (0.74 kB - downloaded 299 times.)
    https://www.tiger800.co.uk/index ... 4101.0;attach=30585
    升级   73%
  • 签到天数: 9 天
    Trident660
    发表于 2025-10-25 14:19:34 | 显示全部楼层 IP属地: 浙江省湖州市
    感谢您这边的答复!但是我这边也无法从这个链接下载,比较可惜
     楼主| 发表于 2025-12-11 09:13:39 | 显示全部楼层 IP属地: 上海市
    感谢提供的网址,但是这个外国论坛似乎停止运维了,不知道什么情况,我后续会关注下再打开看看~
     楼主| 发表于 2025-12-11 09:13:50 | 显示全部楼层 IP属地: 上海市
    GMT+8, 2026-8-30 22:44 , Processed in 0.023891 second(s), 25 queries .
